Doppleganger
- May 24, 2019
- OH-MI: Just like it sounds
- Chris
- K20
The RPO codes on this truck says it has the JB7 brake system. Apparently it does not. I dont know if this is a case of someone swapping things out (doubt it but possible) or was one of those instances where GM used what they had on the shelf.
My rear drums are 11" not 13". My fronts look to be the bigger brakes, but I cant find any specs on what size the fronts are in JB6 or JB7. The GVW is 8600 so it should anyways. My master cylinder was the smaller plastic reservoir, but had yellow paint marker all over it like a yard part. The original owner's sht for brain's son bastardized this truck so bad I would not have even considered it had I known.
Now, in light of the RPO stating JB7, I found / bought an NOS GM booster and master cylinder for that brake (JB7) setup. New JB6 GM Pro MC's are cheap - boosters however, are NLA. I cant even find a PN to look for one. I am beyond p.o.'d with this whole truck at this point. Doesn't help the ********* doing my axles is going on month 9 now with the front.
So before I seriously consider parting this thing out and cutting bait, I have a few questions that hopefully someone has already done.
Can I use the booster and MC from the JB7 with the smaller brakes (I know the rears are, but not sure on the fronts)?
What is required to upgrade the rear axles to 13" and the fronts (if they also turn out to be smaller)? I would imagine its all bolt-on parts.
Can the rear axles be pulled without removing the diff cover? I know some do - some dont. No idea on this one.
Does anyone know the PN for the JB6 booster (if I cant use the one I have)?
Thanks.
Thanks.
