Body mount bolts
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Ok guys, I got my suspension lift in and i've been working on the body lift. I got all of the bolts broke loose except for two(4 actually) the two in the rear should come off just fine they're just in a crappy spot.
The two I have problems with are right behind the firewall, i figured if i had problems i could just access the nut right above it, so i pulled the carpet back and wouldn't you know, there are no nuts there. I'm guessing they are inside that floor pan support. The nuts aren't spinning, its just ridiculously hard to turn the bolts even with a big ass breaker bar, and that's quite a bit of bolt to turn out and i'm getting tired of it haha. One question i have is how are they mounted in there? Are they just tack welded to the body or do they have some kind of special nut?
I'd like to cut it out or something, other than continuing to wear myself out every time i touch it and get more and more frustrated... I've been soaking the crap out of it with pb blaster.
Any tips or tricks on those two? If not ill just keeping prying on the damn things:lazer:
Moderator
They are captured square nuts inside the floor support. Usually the bolts either simply come out or the square nuts spin in their cages. Maybe you are lucky and the bolts are just over-torqued. Put a longer bar on it, or a cheater pipe on the bar... they will either break loose, break off, or spin the nuts.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
That's what I figured. What the hell am I supposed to do if the nut starts spinning? Cut a notch out of the floor support? They're not over torqued because I got them to break free but then after a turn or so it gets just as tight as it was when I first broke them free, so they're just really rusty.
Don5
West Virginia
Don
k15
MY 2 Cents FWIW. I would use a round metal cutting hole saw bit and cut down through the floor. Once through the floor I would either weld the nut to keep it from spinning or put a wrench on it. I would weld the nut though before buttoning up the hole. I would weld the cut piece of the floor back into the floor. Cover with vinyl or carpet never to be seen again.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Punching a hole through the top sounds like a way better idea than going through the side of the floor support. That might make the removal easier for me too..
I'm positive the nuts aren't spinning, I can put all of my force on it and it will break free slightly, until it gets as tight as it was and I have to get another bite on it. Its just really rusted together. Now lets see if I can get right on top of the nut when I drill the hole:rofl:
Greybeard
Iowa-under a rock
Randy
75 something (maybe ???)
k10 and a 1/3
I work on a lot of old farming implements that have sat outside for decades and have stumbled on a few tricks and some commonly known ones that I never learned. For starters never try to keep removing a bolt after it starts to seize once you have broken it loose, all it will do is seize tighter. Tighten it back down, if it frees up while doing this you haven't stripped the threads yet. Then muster all of your patience and your neighbors too, it's gonna be a long boring process from here. Douching it with PB isn't doing anything from the bottom but making a dark brown or black smelly mess. As you said, it has rust on the exposed threads on top and inside the support. The solution is obvious as long as the bolt freed up when it is re-tightened. If it did not, break out the hole saw or hot wrench. If it did, turn it out until it resists, force it a smidgen more (about half a flat) and then turn it back in all the way, repeat ad nauseum until it comes out which it will eventually as long as the bolt does not break (a body mount bolt is unlikely to break easily). What you are doing is cutting the rust off the exposed part of the threads, hopefully without rounding off or flattening the threads on the bolt or inside the nut. This is best done with a smallish air or electric impact because it can take awhile. It does take patience however. I've spent over half an hour removing one bolt doing it this way but the bolt ended up being reusable. Factory bolts and nuts are generally very high quality fasteners. They cannot afford the liability of anything less, even if the components they are holding together are made out of aluminum foil. They can argue a case about component failure, not so easy about a fastener failure.
Georgeb
Wisconsin
George
K10 Burb Z71
You cam also bend up an arisol can straw so you can stick it up in where the nut is and get the Penitrating oils on the threads where you need it. This does work but it does take a lot of patience.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
There are two drainage holes on the bottom of the support so I was able to get a good amount of pb blaster in there on the threads. Trust me ive dealt with plenty of rusty bolts.. I did walk it back and forth to try and break it free, my impact wouldn't do it, and I definitely wasn't gonna use a torch lol.
Its funny you mentioned that they use high quality bolts, the one I was having problems with finally snapped off in the center due to the diameter being half the size of the original bolt, from being rusted away. Five of the 10 bolts I removed were about as rusty but not as bad and the body mount bushings were all corroded and rusting away.
So now I have half a bolt stuck in the hole, I think im gonna drill the center of the bolt out and get a little western with it. I did end up cutting a hole through the floor, since 4 inches or so is hanging from the bottom of the cab ill drill it out from the top, then ill collapse it, and probably just use a vice grips and wiggle it out.
That's what I get for living up north haha
Greybeard
Iowa-under a rock
Randy
k10 and a 1/3
I live in Iowa, no good comes off the salty winter roads.
Wondering though, what delirium caused you to want a body lift?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Driveline angles mostly, anything bigger than a 4 inch suspension lift gives you horrible driveshaft angles and everything wears out quicker IMO.
What cons are there to body lifts? The body is riding on body bushings with a flat steel plate on top originally. So what's the difference when the body is just up a little higher off the frame? Sure I agree with the fact that it isn't the most optimal setup for getting in an accident with it, but grade 8 bolts should hold it on the frame just fine. It might move out of place some but other than that, I don't know lol.
By the way, don't take that the wrong way:gathering:
Greybeard
Iowa-under a rock
Randy
k10 and a 1/3
My personal biases I guess.
If they were dangerous the 'I'll save you from yourself' political segment or the MADD group would impose their greater intellect and vastly superior knowledge about all things off-road and make them illegal. They have on just about everything else...
Regardless, I never liked them, either the way the truck felt after installing them (the one I had was poly but it felt like sponge rubber) or the way they made a truck look, and to me they don't transfer a positive tight feeling from the truck. However, I have never owned or ridden in a truck with a 12" suspension lift so that may be a moot point anyway.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
I wanted decent lift but again I didn't want more than 4 inch suspension, and who knows I might not like it! But as for looks I do agree it makes the pickups look weird unless you relocate the gas tanks, but on the suburban it actually doesn't look bad, you can just see a bit more frame under the doors but that isn't bad. Then just get some good thick rubber for the fender wells, the worst part is the bumpers, the front isn't bad but the back bumper looks terrible after.
Greybeard
Iowa-under a rock
Randy
k10 and a 1/3
Back bumper is solved with a good welder, a torch, a magnetic drill or really sharp drill bits and strong arms, a grinder and some salvaged black iron pipe and some plate.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
I was considering getting some oil field drill pipe, since its pretty heavy duty, and I can find it easily and cheap. I just have to figure out how to make it look good lol
Georgeb
Wisconsin
George
K10 Burb Z71
If it were me I would fab some brackets that mount the step bumper up higher and incorporate a receiver style hitch below. Take somthing like a hitch for an 88-98 truck and modify as needed. The 88-98 hitch is wider than the frames on our squares.
dan86
