Body lift swap
Swims350
Logan WV
none
that picture of your front core support mount and the one of the front cab mount is exactly how the back cab mounts have to be those steel cups with a rubber bushing inside or polyurethane ones.
I had to get some for the 83 I had, thought they were missing but found em later. I know lmc has them and somebody may have them on here used, which is where I got mines from.
That's a homemade body lift somebody hacked in there. The real kits reuse the stock bushings and just use a nylon block that's 3 inches for the lift.
78C10BigTen
pennsylvannia
C10 BIG TEN
Old school drilled out hockey puck lift lol
Swims350
Logan WV
none
here's the ones I got from a member for mine when I thought they were gone these are for the rear of the cab....
Preston
Mechanicsville VA
Preston
The last picture in #13 shows the rear cab mounts, what I’m looking at in the picture #10 the bed is setting metal to metal frame to bed and it’s still looks higher than the cab. Just my thoughts may need a larger rubber on the rear of the cab.
Preston
Mechanicsville VA
Preston
Swims350
Logan WV
none
sorry I missed that last pic thought it was the rad support
Swims350
Logan WV
none
nevermind I see it
Swims350
Logan WV
none
ok now that I see things right that last pic in 13 if that has a rubber cushion inside of it then only option left, is shims to make it level with the bed.
well rubber or poly but eitherway if there's a bushing in that upper cup ... then as above shims
If those are new poly bushings you might want to see which one goes where maybe you have a bottom on top? Some kits have the same some have thicker and thinner.
highdesertrange
kalifornia
mike
k30
I am surprised nobody posted this to help him out,
highdesertranger
Preston
Mechanicsville VA
Preston
Thanks Mike
I have it right no bushings on the bed
Preston
Mechanicsville VA
Preston
I’m looking for a stepside bed for this project I found one for thr early 70’s would just have to change the finders
Swims350
Logan WV
none
why would you need to change fenders? Is it not a 73-80 like it's for a 67-72?
Dan Miller
K15SG
Indiana
Daniel
K15
Factory Radiator support mounts look like this , the square one looks like a transmission mount bushing .
Preston
Mechanicsville VA
Preston
It’s the older style not like the square body and it has a notch for a Spare tire
twitch1989
