BLOWER MOTOR WORKS ON ALL SPEEDS BUT HIGH
echo7bravo
Alabama
Adam
K-10 stepside
350/Th400, 4.56 with 35" BFG MT
Anyone know what would cause blower motor not to work in only one of the speeds? Woudn't care half as much if mother nature would leave the south east alone.
Rusty Nail
Rusty
350sbc
I know ! I know!
Hi speed is the fuse holder on the firewall above your distributor.
I changed mine to a modern spade type holder because ye olde glass holder 'twas broken and the hi speed was therefore INOP.
The thread is found under "interior" / Heat and AC
chengny
There probably won't be a fuse in the lead that runs from the junction block on the firewall to the blower relay - not on a 1986 C60 AC system. If there is power at the FW JB, the blower relay is more likely to be the problem:
1975:
1986:
High speed relay is shot.
Dougnsalem
Could also be the "high" position of the switch being bad, right? Or possibly a wire, but I doubt that....
OK EVERYONE! PLACE YOUR WAGERS!!!
I'm gonna guess switch.... Lol
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
I dunno, I have an 87, replaced the switch, relay, blower motor...and still no high speed. I ended up bypassing the circuit and installed a seperate switch and mounted it in the ash tray. I have high speed now when the alternate switch is on and other speeds with the oem dash switch.
Dougnsalem
So you wanna guess a bad wire? Lol
Man, we could have some fun with this....
If you turn the ignition on (engine not running) and turn the switch back and forth between MED and HI you should hear the relay click. If you don't then it's likely the switch. It can be taken apart and the contacts cleaned. If you do hear it click the check the 12V feed to the relay. If that is good, take the relay apart and clean the contacts.
$1 on the relay.
Dougnsalem
$1 on the relay.
A dollar???
Ima gonna havta fold. Too rich for me...
Well.... On second thought- put me in for a dollar too. I'll go for the switch. Anyone else?
A dollar???
I was going to get it from my wifes' purse anyway.
Dougnsalem
Lol. I know that feeling from when I was married. I didn't have any money either. Kinda like Al Bundy...
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
He had a pretty hot wife. I don't know how much that would help being broke, and I don't think he cared too much about what she looked like, but I wouldn't be totally miserable.
I'm gonna guess the blower relay on this one. I've had the switch fail where it would be hot even when switched off, and the compressor clutch would engage as soon as you turned the key. The replacement of it with a good spare cured that problem.
smoothandlow84
Steve
Everytime somebody asks about hi speed it turns into a huge thread.
And @chengny always tells everybody what time it is..
:emotions34:
I went through the entire checklist that chenghy submitted...and still no high speed....none...so I went another route and obtained high speed
nathanjohnson85
