Block Sealer
Anyobdy ever try this ****?
What's it used for?
I am coming across GM sealing pellets work very good. And K & W sealer comes up alot.
Probably the same as Bars Leak. And yes, only try it as last resort. Also, when you do get a new motor or the problem solved for good, plan on getting your radiator worked on, and if its a plastic radiator, its likely disposable and you'd just have to buy a new radiator. The stuff does have a chance of working, but it clogs up lots of other stuff too.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
The general rule of thumb is one application is ok, but any more than that is going to cause problems. Personally, I would only use it to get a vehicle sold but not in something I plan to keep.
I see a lot of posts in a forum search on this topic saying this **** works. Lifetime guarantee. Works with antifreeze.
http://www.steelseal.com/
f1shman
Anything on the market that will seal a busted gasket will more than likely seal up other small coolant passages as well, like a heater core for instance. Remember, if it sounds too good to be true...
Refer to my signature for the other words of wisdom to live by.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
X2. :cool:
Okie-Dokie.
imyourhuckberry
