78C10BigTen
- Apr 12, 2017
- pennsylvannia
- Ted
- C10 BIG TEN
33x10.50x15 are skinny so yes im gunna say33s on stock suspension?
These are all valid points, and they look much cooler too. And I actually kind of like the sound they make. Only real drawback for me is that mud tires are usually more expensive, and they wear out MUCH faster than ATs. I ran mud tread for years but got sick of pissing away money on tires. They are awesome for traction in any situation- snow, sand, wet grass, mud, loose rocks, etc, even on the street the softer rubber usually helps.I guess you could say that, yeah. Usually nothing crazy, but I often find myself having to pull loaded trailers in muddy areas and across soft ground. I've also had better luck with them when driving in snow. But mostly, I don't mind the little bit of extra noise and I find the added traction to be useful.
My uncle used to ONLY run genital grabbers on all his vehicles! I personally HATE a/t tires and will never buy them but i wont go into my preferences.I ran 31s on my '87 burb before I lifted it, no issues whatsoever, looked stock. All terrains don't make much noise the way mud tires do. If they make any sound at all I doubt you'll hear it over the sound naturally made by driving one of the least aerodynamic vehicles possible down the highway.
If you like the look of BFG all terrains then you should look into getting some General Grabber AT2's. Nearly identical tread pattern for like half the price. Only drawback used to be that they were only white outlines and not big chunky raised white letters like the BFGs had, but General must have been listening because a few months after I bought my 33s those bastards switched to full raised white letters. They last just as long, perform the same of not better off road according to some offroad magazines, and they look just as good. For much less money. It's a no brainer. Not sure why anyone would buy the BFG's over the Generals at this point unless it's seriously worth several hundred dollars to them just to see that brand name on their wheels. Must be nice to have money falling out your ass lol
Hah, I hear you, I much prefer M/Ts too but I'm a cheap *****My uncle used to ONLY run genital grabbers on all his vehicles! I personally HATE a/t tires and will never buy them but i wont go into my preferences.
The last mud tires I ran were actually KM2s when they were a newer tread (2010-2011ish I think). I was getting MAYBE 20k out of them max (I drive 20-30k miles a year, not a good recipe). They lasted longer than the older BFG M/Ts I used to run, and WAYYY longer than the TSL boggers I had as a kid (bought a like-new set that allegedly had less than a thousand miles on them, burned them up in one summer). I know the super swampers weren't designed for street use at all, but that still hurt.Have you ran M/T recently? They have gotten alot better in the wear category. My KM2s lasted forever. My Cooper STT even longer. My Trepadors were phenomenal. Older than that and they were all soft compound, more grip than technology.
Hello everyone. I just picked up a 90 4x4 GMC Suburban a couple months ago and right now it has the 15inch wheels wrapped in 235/75/15 tires.
I am looking to upgrade to 17x8 wheels with 0 offset and 4.5 backspacing. I Don't want to do a lift, but not sure how big of a wheel I can get away with without rubbing.
I was thinking about LT265/70/17 (32x10.50R17)or something close to that.
What are your guys thoughts?
Same setup as mine, 3 inch full tuff country spring lift and 33x12.5r15no. the lift was on it when i got it. its all spring and i was told it is 3inch.
It's funny that you mention the Grabbers with RWL because that is exactly what I decided to go with. Well not the AT2s but the ATX which I have read nothing but good things about.
