Biggest Tank in a 86 SB
2000xpsd
ma
j
what is the biggest fuel tank that will fit in a 86 shortbed fleetside??? 16g??? i'm only going to run 1 tank and would like to put the biggest capacity one i can
78shortandwide
Denver
Tom
If you remove the spare tire mount you could put a tank back there like the ones that the blazers came with...I think the biggest saddle tank is 16 gal tho
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
If you do the Blazer tank mod you could run 25, 31 and even 40 gallon Suburban tank if you wanted.
I don't think there's enough room for the 40 gal tank. It's longer than the 31 gal.
2000xpsd
ma
j
25g would be perfect...i haven't searched it yet but are there any good "how to's" on the mod?
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
16 is the largest you can get in a short bed truck in the side
2000xpsd
ma
j
thanks for the info everyone
the only thing i don't like about the mod is the filler neck. i'll look into a clean way of making it work...but if not i'll go with the single 16g
crazy4offroad
K-10
350/SM465/NP205
I was going to do this and run the filler out the back bumper and use the spring-loaded license plate cover. Either that or relocate the filler door like you see it on a blazer.
Squarebody322
