Best place to pull power for an HEI distributor
hiltijoe
ny
joe
custom delux
I'm switching my truck back tools school where is the best place to hook the hei distuberator to.1987 v 20
There should be an unused terminal in the fuse box labeled "IGN". Pull power from that and use a good heavy gauge wire.
spanky55amg
I'll give u $5, a hardy handshake, & 5 fish sticks
Dallas, TX
Spanky
C10 Short Fleet
V8
Since I just went over his with my 84, and I’m sure 87 can’t be too different.... circuit 3 from the fuse box to the bulk head to the distributor. It’s a pink 10/12 gauge wire. If you look up my thread about no starting or ignition or distributor, I have the wiring diag highlighted. If I were at my computer, I could give more info if needed.
hiltijoe
ny
joe
custom delux
so all I do is wire to the pink wire that feeds the coil correct?
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
Correct. Its just a straigh pink wire with no frills. It goes straight to the Bat on the distro. There should be to plugs that go to it, three if you have a tach. One that has red, black, and brown. That goes to the cap to the distro itself. The second is a pink wire that goes to Bat on the cap. The third is, I believe white, that goes to a tach on the Tach terminal. Ill see if I can find a pic, if not, Ill try to take one tonight. I dont have a tach in mine..... (yet, I do have an aftermarket one I need to install).
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
The gray/beige connector on mine is black and that wire would be pink. But you see the brown/black/red connector behind it, and the white tach wire. Its pretty simple. It just needs 12 volts with the key turned to the "Run" position.
twzorek
