Battery post corrosion
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
This is driving me crazy! My 05 Dakota battery post keep getting corroded! No matter how many times I clean them up. My batteries in the square and camaro do not do this. Not even a little bit. Wtf would cause the Dakota to do it all the time. My dad told me along time ago to put some grease on them to help prevent this. I have, and to no avail, it keeps doing it. Anyone no of a trick to keep them Clean? Here's what it looks like.
I know some viniger and baking soda works to clean them but, they don't stay clean. :banghead:
Tia
dvdswan
Port Orchard, WA
Dave
weak alternator? Probably not charging the battery correctly. Try swapping to a sealed battery. The gases escaping from the battery are really what causes corrosion. Undercharge condition corrodes the neg terminal.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Yep new battery is in your future. It’s leaking which is what causes the corrosion.
I use a spray on battery cleaner and then rinse it off then I put some spray on battery terminal protector.
You could also try the little battery post blankets or whatever, they go under the cable around the post and keep contaminants away.
Big Chip
Michigan
Kevin
C35
Crispy
Carbon County, Pennsyltucky
Suburban V1500
X2 on the cables. My Trans Am did this and sometimes wouldnt start. New battery cables got it squared away. I also now use a terminal protector on all my vehicle batteries. No issues since.
Just keep in mind though, it is a Dodge and corrosion will always find its way through. :anitoof:
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
My Dad was a Mopar mechanic years ago. He always sprayed wd40 on posts when needed.
Backfoot100
Florida
Eddie
C1500 Suburban
Carbed 350
Agree on needing new cables.
I used to maintain 3000A backup battery strings and the only thing we ever used was NO-OX-ID to prevent corrosion. Some really good stuff and all I use now.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Hahaha that's what I was thinking.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Guess that's what a Wal-Mart battery will get ya. Lol, the battery died about a 2 years ago at work and Wal-Mart is about a half mile down the road. So a buddy gave me a ride to get a new one. POS! payed about 100 for it too. I'll put some new cables on it too. Alt seems fine but, will check it when get it all swapped out. Gonna install a cold air intake on it this weekend too. So guees there's no better time to do it. Thanks for the info guys.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
I have a 2007 SUV and 2001 car and all I have ever used is Walmart batteries. Never had any corrosion on posts. Can't complain since I have good luck with them. Truck had a Optima red top installed in 2015 by PO when I purchased it. Great so far too!
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Crap cables cause high resistance, which lowers voltage and raises amperage, which leads to heat. Enough heat will break the bond between the metal posts and the plastic battery housing. The same rules apply to all charging and discharging. Resistance = heat.
Crispy
Suburban V1500
I havent had corrosion issues with Walmart batteries. They dont last long enough to cause any problems. Thankfully (I guess unfortunately, too) the warranty process is fast and no questions asked. I tell you what though, once the replacement warranty is up those batteries are going for core.
73c20jim
Tombstone, AZ
Too much fluid in battery. Looks like its leaking from the cap.
eatfood
