Backfiring
liam
Seatle Washington
Liam
k20
Truck is backfiring when it goes over 1000 rpm already adjusted the carb and timing any ideas on what’s going on
How did this start? Any work done recently? Seems like you've been working on it was that before or after the problem? Did you do plugs wires,cap,rotor, if so double check the plug wire routing at the cap and plugs,then check it again. If none of that checks out get a vacuum reading and do a little research as to what your vacuum reading tells you. There is a lot more to it than numbers. It can find all kinds of problems.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
How did you adjust timing and the carb? What's the timing at? Need way more info
Idle mixture screws only control idle. You have to pull the carb apart to adjust or tune.
Copymutt
Colorado
Here is a good read on cause of different types of backfires.usually an imbalance of fuel ratios between cylinders.
This guy is great at starting threads and never giving feedback and just walking away from them. I wouldn't spend much time worrying about his back fires.
Fat 454
Australia
C20 Suburban
Wow - this one's a classic - kind of like a drive by shooting ...
Smitty69
