Backfiring after new plugs installed
JamesMilk
Athens, Alabama
James
Hello,
I'm a new member, but the first repair I have done to her(still need to name her), was changing the spark plugs. I got the old ones out and she needed new plugs so bad(see attachment below). Put in some double iridium plugs from Bosch. And after I relubed the plugs with the silicone jelly and plugged everything back in, only one side of the head is backfiring in the muffler. Still need to find out if im running just slightly lean to have this happen, or if some wiring needs to be replaced. I did notice one of the plugs was drenched in fuel when I removed it. Maybe 1 cylinder isn't sparking off... anyways if y'all have any experience with this, I would love to learn! Google gives bad advice!
JamesMilk
Athens, Alabama
James
I will recheck wiring positions, and update what I find. Thought I put them all on correctly, but i did do the right side 1 at a time and the left all at once, so that may be the issue.
MrHorsepowerLSx
New Jersey
Jeffrey
K35
Popping the hood and looking at the motor the cylinders will go like this……..
Note: cylinder 1&2 are going to be the closest to the accessory drive
Drivers side cylinders goes as follows
1-3-5-7
Passenger side cylinder goes as follows
2-4-6-8
Find the number 1 position on your distributor cap and bring that plug wire to the first cylinder on the drivers side. Then start running your plug wires one at a time in a CLOCKWISE motion 1-8-4-3-6-5-7-2
JamesMilk
Athens, Alabama
James
1-3-5-7
2-4-6-8
Soo....
It seems I did swap a few cables that were cables on the left side... lol. 4&2 we're swapped and so was 6&8. Suprised it started tbh.
DanMcG
Central NY
k10 k10
Good news, now onto the next problem!
And as an old timer, can ya tell me what is silicone jelly?
MrHorsepowerLSx
New Jersey
Jeffrey
K35
Silicone jelly is really called Dielectric Grease, it’s purpose is to Protect electrical connections and wiring from salt, dirt and corrosion. It helps extend the life of bulb sockets. It Prevents voltage leakage around any electrical connection, it can also prevents spark plugs from fusing to boots.
cutlerfab
