Any way to speed up my wipers?
mrgoodwrench
MN
mike
silverado
So my wipers are working and as far as i can tell working properly. They have all speeds and the linkage has been dissassembled and it is free and lubed. So i think it is working properly. My question is is there anyone out there that has found a way to make them faster then they were from factory.
Sent from my SAMSUNG-SM-G930A using Tapatalk
mrgoodwrench
MN
mike
silverado
I do notice a change in speed in all speeds but there ia no way that this high speed can be good enough. I would have to drive 20 in rain. So im new to thease trucks were they all this slow or do i have something wrong?
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I had the same issue, plus it wouldn't park right anymore, so I just replaced the motor. It's actually very fast now, and I don't worry about having to drive through rain.
Evans Ward
GA
Evans
Sierra Classic 1500
That's a very good question as we're all in that same boat. An upgrade on wiper speed would be nice and definitely much safer.
mrgoodwrench
MN
mike
silverado
Im going to check the power and gnd at the motor and if they are up to snuff its getting a new motor.
Georgeb
Wisconsin
George
K10 Burb Z71
Pssst...... RainEx helps alot
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Yes! My half-brother used to have a $500 1981 Olds Omega with no wipers, and he used RainX in lieu of wipers.
Georgeb
Wisconsin
George
K10 Burb Z71
You can almost get mezmerized by the drops moving up the windsheild and loose track of driving...... It's trippy!
mrgoodwrench
MN
mike
silverado
That's a good call I have used Rain-X before and enjoyed it I just seem to never remember to put it on I wonder if that will help me with mud as well
Camar068
Air Force Supporting Member
10 yrs Air Force
get the wiper fluid that has it. Problem solved. Doesn't work as well as putting it on yourself. But once you change, that's all you'll use. I'd say the wiper fluid X works 80% as well. Try it out.
77 K20
Montana
K20 5" lift
HT383 fuel injected
I second this. Been using it for a few years now.
beest
indiana
matt
Replace the wiper motor. The 30+ year old motors in our trucks are tired.
Sent from my SM-G920P using Tapatalk
mrgoodwrench
MN
mike
silverado
Im going to check that it has full power and ground and if it does its getting a wiper motor.[emoji1]
chengny
I think that by 1990 Suburbans were only available with intermittent/pulse wipers. You might want to check the module (esp. it's connections) before springing for a new wiper motor.
Since both the HI & LO speed settings are affected, that would suggest an issue with something common to both the PPL & GRA leads that run back to the MFS. The ground path for both speeds (as well as PARK, MIST & PULSE operation) is on a shared BLK lead that exits the column, passes through the module and ultimately is connected to the IP ground bus block (over by the parking brake).
Poor grounds are generally the cause for low current flow - as opposed to a problem with the hot side of the circuit.
Wiring diagram:
mrgoodwrench
MN
mike
silverado
Wiring diagram:
Thanks i definently will check that out. It is slow in all speeds however it does move faster as the switch is turned up its just never very fast.
Brianall
