AIR pump pics please!!
aGood'olBoy
Waterford Pennsylvania
Jeremiah
In most of Pa your emissions equipment just has to be there. Doesn't matter if it actually works. This year i'm going to get a real inspection haha so i need to rig up the air pump. I figured brake lines with nuts welded to the ends resting on the manifolds would be enough to look like it works on that end. But i don't know how its supposed to be routed into the manifold. So if anyone has pictures of their setup that'd be grrrrreat.
aGood'olBoy
Jeremiah
Come onnnn i know someone has to have some emissions equipment on there truck..
MadOgre
NA
NA
NA
NA
NA
That was the first thing to hit the trash can! lol
MadOgre
NA
NA
NA
NA
NA
Followed by the EGR
aGood'olBoy
Jeremiah
Yeah p.o. did the same thing obviously.. And I wish I could but PA and there stupid laws....
MadOgre
NA
NA
NA
NA
NA
Cash Grab!:whymewhyme:
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
Mine were removed also (dual AIR pumps on the big block). I think I had some before pics but my 454 has unique manifolds. I'm not sure if it would help.
CSFJ
I've got a 87 I'm getting ready to redo. All the emissions equipment is still present and accounted for. I'll try to remember to get some pictures tonight after work.
aGood'olBoy
Jeremiah
I'd appreciate pictures from both of you guys but particularly CSFJ. Because our trucks should be identical as far as emissions go.
GTME94
Terry
This is the best I could find.
CSFJ
Ok. here's the passenger side and pump mounting
CSFJ
and more from the pass side
CSFJ
and the drivers side
CSFJ
if you need some pics of where those manifold breather lines tie into each other behind the block, let me know. I can get more pics this weekend when I have daylight if you need different angles or a more detailed shot.
Boone83K10
Boone, NC
Benjamin
man, forget that ****. safety inspection only FTW!!!
alwaysbroken
