Aftermarket A/C?
Edelbrock
Earth
Grumba
K5 Blazer
I see people installing complete A/C kits on non A/C rigs.
I see people installing aftermarket kits that add a new ducting system and vents below the dash.
I have seen people with hitch mounted cargo racks on the back of rig holding a generator and a window A/C system ducted into the cab.
What about adding an electric RV AC system to the top of a K5 hard top?
This seems like the easiest and most straight forward way to do it. Drill a hole in the fiberglass for the airflow. Drill a couple mounting bolt holes. Run a couple power wires. Might need a power inverter, but thats simple enough.
Thoughts?
Auburn, Washington
Might need a power inverter?
No, that’s a must. Unless you were going for the hitch carrier mounted generator, super hillbilly version Blazer.
Or a massive battery bank. (Either massive size and weight or massive budget if going Li batteries)
And a top of the line alternator upgrade and may as well throw a big shore power maintainer in the truck so it’s easy to recharge at night.
Conceptually it’s pretty straightforward and simple though and it would work fine with either the hitch mount genny or a huge electrical system. Both of which make the idea practically impractical.
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
They make 12 volt roof mounted unit. They sell them for use on heavy equipment. I would bet you need a pretty stout alternator to run it.
Auburn, Washington
Good point. They make 12V units for RVs too. Same but with a built in inverter I believe. Might be cheaper option. $1000 ish for a 10kbtu unit. Still need a bank of batteries behind it and a really good alternator if going to run it for any length of time between shore power charging the batteries. Think of it as powering a competition stereo at full volume for however long.
But the more you think about it, even setting it up properly and new everything, it’s comparable or less $ than a vintage air system.
Only more cumbersome due to battery storage requirements.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Auburn, Washington
But in reality, even though it would work great, no one will likely want that if you’re building a clean rig (restoring).
On the flips side if you get a free-ish RV AC unit (even if it fails it’s easy to swap with another of the 1000s of old used rv air conditioners) and can scavenge most of the rest of the parts for cheap, a guy could potentially poor boy together a working AC for under $1000.
Edelbrock
Earth
Grumba
K5 Blazer
Good ideas people - I will check around and try to find a 12V for free or cheap. I think 12V is the way to go. Replacing the alternator would be easy enough, or possibly even add a second dedicated alternator. I have plenty of good heavy duty deep cycle 1000 CCA batteries laying around.
Edelbrock
Earth
Grumba
K5 Blazer
Your suggestions led me here:
RV Air Conditioner, 12V 10000 BTU Top Mounted Heating and Cooling Parking Air Conditioner Set for RVs, Trucks, Vans, Campers​
Regular price $895
From what I read, this unit is very small and compact, and even has a remote control, so you could change temp or tun on/off while driving.
Check out the size, only 6" tall.
And according to the manufacturer, it can be used while driving, and it is designed to run off of your vehicle battery without any electrical system modifications.
This would mount pretty easily to a K5 hard top.
Check out the pics:
Dejure
Eastern Washington
Kelly
C15
Years ago, a buddy spent a pretty penny on a nice inverter to power the heater for his pressure washer. Tried to tell him it'd not be enough, but. . . .
Frustrated, he gave it to me. Nice unit. Could run around 500 watt power tools off it and it would shut down, if it was taking your battery too low to start your rig.
I'm going with that this is the boat you'll find yourself in.
In the end, you have the cost of the roof mount, a GOOD inverter, a heavy duty alternator, likely a second battery, diodes to stop the drained battery from draining the truck battery.
Starting to get closer and closer to a real after market air conditioner, in price.
Edelbrock
Earth
Grumba
K5 Blazer
As an Amazon Associate we earn from qualifying purchases.
Why on gods green earth would you consider hacking up your truck to do something like this? Either fix the factory AC so it works properly or put in a good aftermarket setup. If you can't afford it, ride with the vent windows turned open.
Doing this will only completely ruin any value your truck may have, likely won't work well at all and most likely you'll end up very close to the same cost if not more than a good OE or aftermarket setup designed for the truck.
80k10ls
