Adding a Key Fob
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
Can a remote key fob be added to an 85 C10 that has power door locks?
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
I don't see why not.
Just have to pay someone to hook it up the way you would a remote starter. I don't know of any DIY kits but I've never looked because I've never had a truck with power locks. But it's a simple wiring thing with a radio transmitter, it can't be too hard at all if you know a little about electrical stuff.
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
Absolutely yes!!! My first job was doing just this thing. There are a plethora of kits available for just the fob or you can go ahead and install an aftermarket alarm. MOST good alarm kits come with a fob that unlocks doors. Hell you can have remote start, alarm,windows down,doors the whole nine.
RoryH19
Rory
R10 Silverado SWB
Yes not an issue. My R10 has a simple lock and unlock alarm setup.
For my k5 it's a remote start alarm. Of course it locks and unlocks, turns park lights on...I also set it to lock the doors when I put it in drive and unlock when the key is turned off. Will probably add a module to roll the back window down from the fob.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
Thanks, I'll look into those kits.
Since I’m cheap, and have access to a salvage yard that gives me the freedom to wander around and brainstorm, this is probably what I would do.
http://www.montecarloss.com/community/ubbthreads.php?ubb=showflat&Number=975362
Great minds think alike?
I pulled my setup from a '97 Lumina that I parted years ago. I've never installed it because I couldn't ever decide which vehicle I wanted to put it in. I think I just need to go get more and put the keyless setups in a bunch of them.
But on the other hand, I hardly ever lock my doors, lol.
Is it from cars where you use the obd2 connector to program more? My 99 aurora has rke that you have to ground a pin and do that way. No diagnostics in tech 2 for it. It also has pass key ii. My guess is anything rke amd pass key 2 or without anti theft is what you would find the module from? My 99 park avenue has it connected to the class 2 data bus and pass key 3 so no go
It has a dedicated wire that just gets jumpered to ground for programing. On the W body, it's in the trunk.
eskimomann209
Modesto
Marcus
To touch on this a bit. Even if the truck DOESNT have power locks you can still install an aftermarket one for an alarm/ remote start.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I guess they do think alike! I didn’t notice you posted the exact same link. I have that link saved for a rainy day project that I will probably never get around to trying.
Lots of stuff to do before that just like 260 swapping your square!
FenderBanger
