Adapter between SM465 and NP205
Moderator
Thanks @bucket! When you say “a means of giving the bolts more room to stretch”, do you mean that the spacers from the factory (installed between the top of the frame and the nut) allow the bolts to be longer than they would be without the spacers? Ok other words, the spacers come from the factory and they are installed between the top of the frame and the nut (with the bolt coming in from the bottom)?
Yes, exactly. A shorter bolt would have been more likely to break due to frame flex.
Mark80K15
Sicamous, BC
Mark
K15
Ok thanks @bucket, that's good info. I suppose either configuration is structurally the same...
Mark80K15
Sicamous, BC
Mark
K15
A bit of cautionary advice here: during this project I pulled the engine. I forget if I mentioned that earlier in the post. At this point the NP205, adapter, and SM465 are all bolted together, and earlier this week I installed the engine. Just before installing the engine, I noticed that the pilot busing was damaged. See picture, comparing the damaged one to a new one. This is the bushing that sits in the back of the crankshaft, and the input shaft of the SM465 rides in it. I believe it was damaged for the same reason the bellhousing was cracked. The missing mount under the adapter caused massive misalignment in the whole drivetrain, including misalignment of the SM465 input shaft into the back of the crankshaft. The pilot bushing took all of that abuse (which I suspect it is designed to).
Lesson: whenever the engine is out, replace the pilot bushing. Just because.
Maknwine
Virginia
Tom
c30
And finally, another question. See the spacers between the top surface of the crossmember and the frame? Is that correct? I'm pretty sure that's how it was when I took it apart, but of course I didn't take pictures and of course I don't remember for sure. Can anyone confirm if they have the same factory setup on their SM465/NP205?
Very good informative thread here. This is obviously late to the game but I'll add in case it helps someone else, the "not taking before pics" happens to me as well but in your second pic you can see the rust imprint so to speak where the trans mount was mounted to the frame which would prove the spacers were on the wrong side. I've used that type of "imprint" before on other things I didn't record before dismantling parts. Usually all trace imprints would be wire brushed, sanded, and rattle canned prior to with my luck....LOL
Hey, sorry to carry this on, but I still need a little more info. Now that I've pulled the x-member out that the adapter sits on, I only have more questions. Attached are 2 pictures of the x-member out of the truck with the one mount in place. On both pictures, the left is the passenger side.
The first picture is exactly as I found the x-member and mount. There is only one mount, on the passenger side. The front driveshaft attaches to the transfer case on the passenger side also. I don't know if there was ever a mount on the driver's side, but there wasn't one when I took the x-member off.
The second picture shows the same thing, but with the passenger side (upper) mount removed. You can see the broken bolt poking up out of the hole, so for this one mount, the adapter wasn't even bolted on! Just sitting on it. Glad I'm working on this.
So, is there really supposed to be 2 mounts? (I've heard yes and no!). If so, is there any significance that the passenger hole is round but the driver's hole is rounded rectangular? Is it the same mount for both sides? Does anyone have a picture of how the mount(s) bolts to the adapter? Does anyone have a picture of the adapter? Thanks!
this is a drivetrain from a 1977 chevy/gmc k20/k25
The only difference between this and the 1980 we both have is the crossmember sits lower here and the adapter is "Taller" than the 1980
The reason I show you this was I dont have my original tcase or trans in my truck, I have a 1986 np208/sm465 combo. Mines in the shed lol. I know you already have this figured out, but pictures never hurt!!
Other than the differences i pointed out on the crossmember and the adapter height, the only difference yet to a 1980 would be the 1980 has a slip yoke rear output not a fixed.
heres my 1980 drivetrain:
WRW86
Alberta, Canada
Warren
K2500
During all my research, prior to working on my clutch, I read a lot about adapter seals and everything related to the figure 8 bolt NP205, so I thought I would add-on from a round NP205 perspective.
I have an SM465 and NP205 from an '85 1-ton (32 spline, round, synchro model)
I was under the assumption that the adapter should be dry, inside, but when removing the T-case bolts a lot of oil poured out. Further dismantling confirmed that there are no seals in this style adapter and no seals on the output side of the SM465. The NP205 is sealed on the adapter side.
It looks like the taper in the adapter is such that all oil coming from the transmission can't return unless pointing the truck down a steep hill. I seem to recall climbing some steep hills, which is likely why there was oil in there.
this is why the manual and the t case would spec the same fluid as eachother in these years.
WRW86
Alberta, Canada
Warren
K2500
Funny you mentioned that just as I was looking at the shop manuals that call for gear oil in the 465 and ATF in the 205.
nvrenuf
Mobile, Al.
That's a year model / mpg thing.
Moderator
Round pattern and a syncro version?
i looked it up on multiple years, it appears i may have confused being able to use dexron in the manual 465 because of the 4 speed with overdrive manual taking dexron
isted below are sealants referred to in this bulletin:
Quantity Part No. Part Description
1 1052080 Pipe Sealant with Teflon (TM) (50 ml -
1.69 oz)
1 1052917 RTV Silicone GMS Type B (89 ml - 3 oz)
SERVICE MANUAL REFERENCE:
Refer to the unit repair section of the appropriate service manual for the procedures.
Please record this information in any 1988 or earlier model year service manual. 1989 and future service manuals will include these revisions.
SERVICE NOTES:
Refill the transmission with only SAE 80W or SAE 80W-90 gear lubricant. Do not use automatic transmission fluid or engine oil. This may cause foaming out the vent and durability concerns.
IMPORTANT: Some 1988 C/K Trucks equipped with a HM-117 may leak out the vent. To correct this condition, refer to Dealer Service Bulletin 88-44-7B, dated October, 1987, outlining the procedure to add a remote vent system.
On models equipped with the remote vent system, do not use a SAE 80W or SAE 80W-90 gear lubricant that has a hypoid additive (a GL5 rating on the label). This may cause a gear oil smell inside of the vehicle.
nvrenuf
Mobile, Al.
Cool! I was never sure if those really existed.
Interesting, I always thought the true synchronized versions were available for like 2~4 years and only in the early figure 8 style that ended in ‘84.
@WRW86 your 205 has this oiling vein on the rear cover?
hauto85
