77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
Wondering what to do here... all of the accessories I have added (and previous owners) have been wired directly to the battery. There are lot of wires to the battery now.
I recently put in a larger alternator and it didn't help much at all. In doing some reading I found that the alternator companies recommend that all accessories come from a junction block away from the battery. Then run a big gauge wire from the back of the alternator to the junction block.
I know there is a factory junction block on the driver's side near the brake booster... but that is very far from the battery where all the accessory wiring is already at.
My idea is to remove all the accessory wiring from the battery and put it nearby on a junction block right there. Then run a 8 gauge wire from the new junction block to the existing junction block near the brake booster.
Is there a flaw with this plan? Or am I missing something? Just want to do this once.
And where does the voltage sense wire from the alternator go? Think I heard once it goes to the horn relay? Why would it go there? Shouldn't it go to the factory junction block near the brake booster?
The volt gauge drops down at night with the headlights on, fan set to medium, and the wipers on. The truck has good grounds everywhere already.
