Ac brackets and locations
joshcoleman1716
Louisiana
Josh
I was needing some help with my a/c system on a 79 k10 with a 350. The truck came with factory a/c, but previous owner removed the compressor and all mounting brackets. Would anyone happen to have pictures of the brackets needed, and how they mount so I can try to locate all needed parts.
h
to my knowledge this is what it would look like
but it looks slightly different than diagram says
75gmck25
Northern Virginia
Bruce
The original brackets for the A6 compressor are really sturdy, since it was about as heavy as a small boat anchor. They also get in the way of everything on top of the driver’s side valve cover. You can drop in a new Pro6Ten aftermarket compressor, which is aluminum with the exact same form factor and connections as the old A6.
The other choice is a Sanden mounted toward the front, using Alan Grove or similar brackets, and adapters or new hoses to connect it to the stock condenser and evaporator.
You will also need a new filter/drier, orifice tube, green o-rings, and a complete flush of the old R12. It’s recommend to start with an R134 amount that is about 75-80% of the recommended R12. Then use your A/C gauges to make further adjustments.
Cyrillious
Toronto
Cyril
K10 Suburban
this bracket you will need to secure the compressor to the side of the exhaust manifold.
hauto85
