AC bracket manifold bolt
johns87
Orlando, FL
I have an 1987 350, and was removing the headers that where on there. The AC bracket bolt broke off in the block and I'm trying to find a replacement stud. I know its a 3/8 x 16 and looks like overall length was 3.5 inches, but I cannot find one anywhere. Has anyone else been able to source one, or have any recommendations?
Preston
Mechanicsville VA
Preston
We have a Bolt company here called Trios I think there is also fastenal not sure of my spelling of either but you May do a search on the www and find them. Also the lumber stores have some bolts not sure if they have the right one and tractor supply. Good luck hope it’s not too hard to get the broken one out.
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
I had to use a piece of grade eight all-thread and a jamb nut in the middle when that happened once. I was told you could get them through a dealer but haven't confirmed it.
Doppleganger
OH-MI: Just like it sounds
Its a stud? Would a piece that length of threaded rod work? Think I have some.
Also think I have a grade 8 bolt that length too.
Moderator
You mean the bolt that has a 1" or so stud on the head of it? That goes in one of the forward manifold bolt holes?
I have a few of those, but unfortunately I'm not home for at least a few more days. But I might be able to get my wife to find one in the garage. Maybe, lol.
johns87
Orlando, FL
That is exactly the bolt/stud. I finally had to give up and trailer it to the exhaust shop that was going to work on the exhaust. I tried an extractor, but after that broke off in there, going to need to try something different. The exhaust shop said they could weld a nut on it and be done... so we shall see. He also said he had some threaded rod that he'd be able to use.
Nothing like trying to do it to save $200 in labor and then having to spend 200$ to fix it...damn truck, it hates me I swear.
Doppleganger
One thing I always have in my box is a 1/4" and a 3/8" carbide ball endmill (4 fluted). Put it in a drill and slowly turn whatever is in there to dust. I watched a guy fight with a broken 8mm bolt in a block for 2 hours as he didn't want to damage the threads - I used a 1/4" end mill and had it gutted in 2 min. Have to almost watch yourself...it goes through cast and most anything else like butter. Grade 8's are a PITA but will still drill out.
My 2c...and 20yrs of tool and die. lol
donnieray
Roanoke Rapids NC
Donnie
350,355;350.
Damn good advice, I'm in industrial maintenance and deal with broken bolts way to much. Going to find those end mill bits right now.
Doppleganger
The Niagra Cutters are a great deal - very reasonable and good quality ($15-ish each) - I see them on feebay alot for decent prices. You can buy the 'bigger brands' like Kennemetals, etc for 2-3x more but IMO not worth it. Pretty sure the NC's are made in USA too (at least the last batch I bought were). I get them 2-3 of each size at a time as availability can be sporadic - machine shops buy 100's at a time. Big thing is to make sure they are 4 fluted. Two fluted will catch and chip, especially in a hole with jagged pieces of broken drill in it - then you have particles of carbide to add to your broken bolt....next up from there is a larger hole and helicoil only because they dont sell thermonuclear devices that small :Sumo: . A four flute is like a clenched fist....will burrow through with little chance of chipping. Dont push too hard either - can go too deep too fast (no joke).
I've also used them as starters for holes in thick steel too. They sell carbide drills but I still like these better for the chipping reason.
donnieray
Roanoke Rapids NC
Donnie
350,355;350.
I'll look for the NC brand. We have some ball end mill bits for our milling deck but I'll be buying some for personal use. I just never heard of using them in a hand drill. BAMM!
4WDKC
Southern Florida
Kacy
perfect time to swap in a serpentine belt system.
WFO
Texas Panhandle
I never cared for all that bulky lookin cast aluminum on a serpentine setup.
Plus, I like having that second belt turning the water pump if you need to limp on in to the next town after throwing an alternator belt.
4WDKC
Southern Florida
Kacy
Ive never seen an serp belt thrown, Ive seen idler pulleys lock up, or an alternator explode the internals ( it rattled and pieces fell out when you shook it). hell I just sold under drive pulleys to a guy that had an air bag blow causing the truck to slam down on the big wheels sending parts into the serp belt that caused 2 of the 6 ribs on the belt to shred off but he still was able to drive it an hour to my house to buy the pulleys and belt.
But if you dont like the looks its understand able.
Rusty Nail
Cowboy of both Time and Space
Russell
350sbc
In many cases the trucks have spent a LONG TIME getting treated like sh- and I think by the time they make it HERE, they are straight-up JADED.
It's a labor of love to set it all straight! At least that's what I have told myself previously..:shrug:but now waiting on the bill from my trans installer.
souixchef2
