A quick wheel question....
quaddriver
Cook Forest PA
Ed
Chevy R2500
The big one
Looking for aluminum wheels for my 90 R2500 and a guy from pitt responded to my ad with wheels from a early 90's' fold bullnose in 8 hole, 16x7. does anyone know if the back spacing from ford to gm is acceptable?
Are you sure it's even the correct bolt pattern? I know that Chevy and dodge shared bolt patterns during this time but wasn't sure about Ford. :think:
Georgeb
Wisconsin
George
K10 Burb Z71
Yeah, I believe the bolt circle is the same. I ran 90's GM 8 bolts on a '76 F250. The center hole on the Ford is larger so I had to turn the holes open a bit. I think going ford to GM will work but some quick measurements would be a good idea.
quaddriver
Cook Forest PA
Ed
Chevy R2500
The big one
I think it will work, he is an hour away...8 on 6.5 holes, it came from a plain jane f350 4x4 SRW so it had the monster sized hubs - as big as or bigger than the 14BFF. center caps might be an issue getting! ford factory wheels. the clearcoat was leaking so he beaded them and did a black coat that looks, well smokey...might be a nice addition for $150 for all 4
Don't know the offset, but they do fit. I have seen one truck that ran the "conversion" threaded style lugnuts in order to fit modified late model Chevy centercaps.
highdesertrange
kalifornia
mike
k30
correct me if I am wrong but aren't 1 ton wheels hub-centric. meaning the hub centers the rim not the lugs. at least on my 1 ton that's how it is. highdesertranger
Georgeb
Wisconsin
George
K10 Burb Z71
On the GM trucks they all were. The heavy fords were too the f150 was not
highdesertrange
kalifornia
mike
k30
yeah so the center hole must be for a chevy or ford or dodge. you can't interchange them.
I just reread and see he is going to put them on a 3/4 ton. for some reason I thought he was trying to put them on a 1 ton. so never mind. highdesertranger
You can interchange them if its a single rear wheel truck. Yeah, the original Chevy wheels are hub-centric and also have tapered lugs, but the tapered lug seats themselves do a fine job of locating the wheel. So long as the lugs are checked for proper torque several times after install, but that should be done anyway.
mick84
