A clutch pedal adjustment question
CRM
Pasco, Washington
Casey
K2500
350 CI
For years I've put up with the clutch pedal going almost all the way to the floor to shift gears so I thought I'd try to make an adjustment. I got underneath and pulled the adjustment piece and noticed what looked like a worn spot. I'm attaching a picture. Is this worn or was it originally like this?
where at does that fit in the system, i can look at mine
Yep, very worn. When new, that pivot point was the same diameter for the whole length of it.
CRM
Pasco, Washington
Casey
K2500
350 CI
Is this a part that can be bought, or repaired?
CRM
Pasco, Washington
Casey
K2500
350 CI
Thanks Turbo4whl. Amazon had a Dorman version for under $9. I don't normally go with Dorman but all i need is the worn piece. If it turns out to be inferior I'll go with one of the other brands.
Thought about that Idahovette but I don't have a welder.
CRM
Pasco, Washington
Casey
K2500
350 CI
Received the new part. Looks like it will work although it's not the same exact size. We'll see soon.
imyourhuckberry
