98 Chevy t Case
Blackdog3
Lansdale, Pa
Silverado K30
5.9 Cummins
hey Gang,
Took out my rear drive shaft today to do the u joint. When i took the driveshaft out a good bit of fluid came out with it. Not sure if that is normal? For sometime i have had a little bit of drip from that area, i was told the t case seal is probably shot. Its not a big drip but now that i got it apart and seen the fluid come out like it did i am thinking it would be a good idea to fix it.
98 Chevy 1500 automatic
Thanks
IF I understand what you're saying right, you should get a good bit of fluid out of it. IF you didn't that means your t case is low on fluid.
Blackdog3
Lansdale, Pa
Silverado K30
5.9 Cummins
Alright, so that is normal for it to come out when the you take the drive shaft out. Just wanted to check.
Yep, if I had to guess, you shoulda lost a pint to a quart.
davbell22602
Bunker Hill, WV
I Dont
Have
One
It did the same thing on my 97 K1500 automatic too.
Blackdog3
Lansdale, Pa
Silverado K30
5.9 Cummins
That would be about right sir... all i know i wasent ready for it!
Now don't forget, when you put the dsaft back in, top off your tcase fluid. I'd check to make sure, but I think it just takes Dextron 2 or 3 Auto trans fluid.
davbell22602
Bunker Hill, WV
I Dont
Have
One
What about dexcon 6?
oneluckypops
Sedalia, Mo.
Luke
No it is tooo full, The fill plug is sits lower on the back of the tcase then the outputshaft, so if fluid runs out of the rear seal with the shaft removed it is over filled, which would be the Front inputshaft seal leaking, your transmission is overfilling the transfercase.
:eek: That could be true. Almost every dshaft I pulled from one of the aluminum Tcases, had about a pint come out, with exception of the ones that were low or out of fluid completely. :shrug:
oneluckypops
Sedalia, Mo.
Luke
lol doesnt suprise me, nearly everyone I have done has had a bad seal in it.
Where the hell you been Pops, Seems there was a thread or 2, or some news on the site you needed to know about, I can't recall now. Be sure to look around.
EDIT: I remember one of them, KC7's truck with the Air Box Pics and the GMT400 dash install. He's done some updates.
oneluckypops
Sedalia, Mo.
Luke
been busy man, I will try to find the threads and check them out
davbell22602
Bunker Hill, WV
I Dont
Have
One
So a pint of trany fluid out of the tcase means bad rear tcase seal?
NO, Pops is saying it means the trans rear seal is bad allowing trans fluid to leak into the Tcase and causing the Tcase to overflow. I've heard of that and know it happens, but I was also about certain, it's normal to lose some Tcase fluid when you pull the dshaft out.
504SquareBody
