91 Suburban headlight issue
k10mojo
Northern Kentucky
Christian
K5 Blazer
Hi everybody, I was driving down the road the other night when all of the sudden my headlights went out. Now my dash and interior lights were still working and also my running lights and brights. So I replaced the head light switch and they still dont work and I fear a wiring issue. Does anyone have any idea what it might be? Or maybe has had a similiar problem? Any help is apprieciated!
73c20jim
Sierra Vista, AZ
C20 2WD Custom Deluxe
350 CID 195/260 HP Goodwrench crate
Hi beams work but lo beams don't?
Check wiring going to lo beams, could be broken or eaten by rodents.
Also the Hi/lo switch might be busted.
I had a similar issue with an '88 Camaro once, except the lights would start working again after parking for a while. I cleaned all the harness grounds in the front end and it never happened again.
Lostranger
Marion, NC
R30
I've had similar symptoms from bad dimmer switches.
k10mojo
Northern Kentucky
Christian
K5 Blazer
Okay so I replaced the headlight switch under the dash, I replaced the headlights and now Im wondering if the connections are fried
Crispy
Carbon County, Pennsyltucky
Suburban V1500
There is another switch near the base of the column. Its call the headlight dimmer switch and it looks like this:
You can trace it down by following high beam rod from the column down to this switch. When you pull the lever this is the switch that changes between high and low. Have a look at that switch. It may be rebuild-able or serviceable.
Ricks 87
