- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
My 90 burb has had the smog pump removed by previous owner. He put headers and aftermarket cat on it. I will have to look and see where the vacuum advance is hooked up. it runs great but it does surge a little at idle. Idles fine until its warmed up and then it will idle around 700 rpm for 10 seconds or so and jump up to 950 for about the same time and only does this in park.![]()
A '90 wouldn't have a smog pump to begin with, it doesn't have a vacuum advance either. Vacuum advance was only on carbed trucks.
