87 V10 driveline
WP77
Naples, Idaho
Steven
I'm in need of a driveline for an 87 V10 longbed. I haven't found one yet, but have found a couple for Suburbans. Weren't the long beds and Sububurbans the same wheelbase? If so, would the driveline be interchangeable?
Edelbrock
Earth
Grumba
K5 Blazer
Have you checked eBay?
WP77
Naples, Idaho
Steven
Yes that's where I've been looking.
Edelbrock
Earth
Grumba
K5 Blazer
How about car-part.com ?
Its like... Every junk yard on the planet, all in one place.
What are you actually needing? A drive shaft? An engine,transmission and rearend?
WP77
Naples, Idaho
Steven
I ordered a rebuilt transmission and transfer case. Now I just need the driveline. Lost all 3 in the fiasco.
WP77
Naples, Idaho
Steven
I've used them before and will check. It's weird on Ebay I can't find a single one.
So you need a driveshaft,just the rear one? Or both? Use drive shaft as your search criteria not drive line. I think you'll have better luck. I believe there is a couple inches difference between burb and pickup on wheel base. Doubt it's a swap. Also unsure if carrier bearing is in the same location.
KAR1130
