87 to a 89 crewcab grill conversion
87hotrod
Lula, GA
Dustin
I was wondering what all i had to change to put an 89 crewcrab grill in my 87 c10 i was told that i have to change the entire radiator cradle if i wanted to put a 89 grill in it.
DREAMER
Baytown, tx
Dreamer
High Sierra
The radiator core support...the grill...the lights...the pigtails that go with the lights, hopefully the donor has plenty of wire from the pigtails to keep the splicing to a minimum...there's a small metal strip that goes between the bumper and the grill itself...I would recommend to change out the mounts under the radiator core support since its gonna be off anyways, wouldn't hurt.
That's the correct way to do it. I've seen a few guys cut up their existing grill an "make" it fit. Personally I don't like to do it that way. If you're gonna do it...do it right.
87hotrod
Lula, GA
Dustin
oh yea i wanna do it right thanks now all i got to do is find a donor
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
You might want to do some more checking because as far as i know if its coming from an 89 1 on truck then you shouldnt have to change the core support. From 80 to 87 on all 1/2, 3/4 and ton and burbs and blazers used the same core support and ton burbs and blazers used it till 91 when they changed the body style to the same as the newer truck.
DREAMER
Baytown, tx
Dreamer
High Sierra
Double check it and then triple check it. 81-87 Trucks/Suburbans used the same doors, fenders, core support, etc. 88-91 Suburbans and Crew cabs Only used the same doors and fenders, but different core support. Regular size trucks from 88 and up went to the new body style.
The '89-'91 core support was changed to accommodate the newer style headlights.
nvrenuf
Mobile, Al.
'89-'91 squares used different core supports than the '88 & older trucks. Within those last 3 years there were still 2 core supports, 2 headlamp vs 4 headlamp.
Be sure you get the right one...
Dennis Blom
