85 k10 fuel return line
bls77red
springfield,il
brian
k1500
Doing a Ls swap and need a place to run return line back to fuel tank. Mine has dual tanks. And I have put a walbrow fuel pump inline from the tank selector forward.to a filter regulator combo. And just need ideas on return line to tank
MadOgre
NA
NA
NA
NA
NA
The stock fuel return line is found on the drivers side beside the rad. It is a hard line with a rubber hose end that connects to the charcoal canister. Why not use this line ?
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
That's a vent, not a return, I thought? It's also something like 1/4" tubing, which probably isn't enough to return enough fuel to keep fuel pressure from going through the roof.
MadOgre
NA
NA
NA
NA
NA
Oh hahahaha yep your right :)
MadOgre
NA
NA
NA
NA
NA
Man do I feel blonde right now!
Georgeb
Wisconsin
George
K10 Burb Z71
I would buy a coil of 5/16 line and run it right next to the supply. Mabey even take the supply out so I could bend the return to match it better. New line retiner clips to hold both of them to the frame side by side.
bls77red
springfield,il
brian
k1500
The return line will be low pressure. I did take the vent line loose at the tank selector off.because my truck has two tank. And I blew compressed air through.it seem to handle the volume of air that was going into. Thinking I might try the vent first. I see only option would to be a return tapped into one tank. But then when the other tank is used its only returning in one
Georgeb
Wisconsin
George
K10 Burb Z71
You will need to use a tank selector valve with the ports for both supply and return so you can have both tanks full otherwis you could overfill one. You also must have a tank vent so you shuld run a dedicated return if possible.
MadOgre
NA
NA
NA
NA
NA
Ya if it were me I would just bite the bullet and go get 2 new 3 port fuel sending units and plumb up a return line into that 3rd return port
chevy-lvr
