jkimmick
- Apr 27, 2026
- CO
- Jeffrey
- K1500
Hey guys, brand new here, so I'm not sure if this is the correct thread for this. I've got an 84 k1500 that I've had issues with the turn signal lever since I got the truck 3 1/2 years ago. Left turn cams and holds fine, but turning right, you really had to push it pretty hard to engage the cam to the right. The lever is hitting the shroud like something is loose in the column. Just kind of dealt with it until it broke the lever and the cam eventually, so I replaced both, and that made it even harder to cam to the right. Not sure what to check at this point, but it keeps bending and breaking levers so I'd like to figure it out as the levers are 40-50 bucks a piece.
