78 silverado grill measurements
Corey Roska
Walla Walla, wa
Corey
78 silverado
Recently bought a 78 silverado stepside. The grill and lights are off an early 80's chevy (stacked headlights). The guy I purchased it from was of no help. Does any one no the measurements of the grill opening(fender to fender)? Hoping the front fenders and hood aren't a mismatch for the year. Can't find these measurements any where.
Big Chip
Michigan
Kevin
C35
Post a picture and we can help you out.
Stacked headlights is '81-'88. If you want to run a stock '77-'80 grille, you are looking at a complete clip swap.
Corey Roska
Walla Walla, wa
Corey
78 silverado
Here are some pics
Corey Roska
Walla Walla, wa
Corey
78 silverado
Actually answered my own question, the horizontal light on the fender would be vertical if it was an 80's fender or lower. Looks like I'm buying new fenders and hood. Thanks for the help
Big Chip
Michigan
Kevin
C35
Just an FYI for you, you're going to need a lot more than fenders and a hood. You'll need the core support, hinges, bumper and brackets, etc. Are you positive the cab is a 78 cab converted to the '81 and newer front clip?
Corey Roska
Walla Walla, wa
Corey
78 silverado
Yeah, pretty sure. I noticed when I bought it that the gaps where off. Factory stickers both on the door and glove box show 78. I can deal with the side lights are being horizontal instead of vertical if I can get an original grill and lights to mount right. I'm not going 100% original. Just want the grill to be correct. If the spacing on the front is the same, I can fabricate what is needed to mount it. Thanks for the info. New to the older chevys. Love it either way. Thanks for your help
Big Chip
Michigan
Kevin
C35
You have to change the whole front clip for a 78 grille.
Corey Roska
Walla Walla, wa
Corey
78 silverado
Well, looks like my winter is lined out then, Lol. Thanks guys
dvdswan
Port Orchard, WA
Dave
With the hood open, what does the cowl look like? If its a 78 cab it will be modified, if its a 81 and newer won't look modified. That is in order to put that front clip on.
80BrownK10
Greenwood, SC
Nate
Recently bought a 78 silverado stepside. The grill and lights are off an early 80's chevy (stacked headlights). The guy I purchased it from was of no help. Does any one no the measurements of the grill opening(fender to fender)? Hoping the front fenders and hood aren't a mismatch for the year. Can't find these measurements any where.[/QUOTE
Clip swap? Does that mean fender swap?
Your truck has already had a clip swap to the 81-88 fenders. He is saying you need to go back to the 80 and earlier fenders and front.
Hard
