78 8.5 front auto hub install order?
redneckgames
North Carolina
Brad
I need some help. Forgot to take a picture when I pulled it apart and most of the online info isn’t the same style.
78 k10 corporate 8.5 front axle. Auto hubs. I have the bearings set and lock nut tight and cannot remember the direction the gear goes or the order. First time messing with straight front axles. I tried searching and couldn’t find this setup so had to ask.
redneckgames
North Carolina
Brad
I know the snap ring is last. The thin cap and gear and spring is where I’m lost.
Thanks in advance!
redneckgames
North Carolina
Brad
I’m assuming it goes like this?
awar
K35
Yes, turn the clip over.
Spring seat with the lip out, then the spring. Next the splined drive piece with the small part out so you can grab it if it gets stuck, last the clip. Study the clip, one side will be flat and the other side will be slightly rounded. The flat side goes out to hold the load. That is the same on all clips.
redneckgames
North Carolina
Brad
Thank you! I’ll give it a try here in a bit.
Do you ever put a little silicon on the outer cover mating surface? It had some on it when pulled. Figured a small coat wouldn’t hurt as long as it doesn’t get in the hub itself.
nvrenuf
Mobile, Al.
FYI, you have “drive flanges” not auto locking hubs. Drive flanges were used with full time 4wd up to ‘79.
I don’t mean to split hair but true “auto locking hubs” (which could switch from free wheeling to locked based on torque input) were used ‘81+, these were a very different mechanism.
Your moon cap should be a press fit, if it’s not I’m pretty sure Spicer still makes them.
redneckgames
North Carolina
Brad
Thanks for the explanation. I had no clue. So I appreciate it. Might be why I couldn’t figure out pictures or a video.
awar
K35
We always added some silicone sealer with those style drive hubs. Helps keep the water out. Did you pull the spindle and replace the two seals and pack the Torrington bearing inside the spindle? I think the part number was SBK1 for the 1/2 and 3/4 ton front axles.
alex7915
