77 K10 LS Swap
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
I did the harness myself. I have gone back and verified all the O2 lines and voltage. MAF is in stock location.
Madhorn
AR-Arkansas
Ken
I have confirmed that the DTC codes are heater circuit. The O2s I installed are Denso. I have heard that AC Delco O2s have better heater circuits. But doesn’t Denso make O2s for AC Delco?? Hmmm
rpcraft
Robert
LS 6.0 364 CID
Maybe it doesn't like the fact you cut the big booger tube off the intake vent, lol....
Nicholson72
Ca
Ls 5.3
Hey for your cooling system what did you do with your steam hose? You block it off? I took my truck for its first actually drive today and it’s running pretty warm and seem to build up a lot of pressure
rpcraft
Robert
LS 6.0 364 CID
Generally the best thing to do with your steam hose is add it back to the heater return line like the factory does. There is a fitting made specifically for it. Here is a link to the info about it and part #. It is available on Rockauto.com but using the part # you can probably find it at a local supplier if you want to hunt it down today. https://www.rockauto.com/en/moreinfo.php?pk=7936060&jsn=255
Nicholson72
Ca
Ls 5.3
Oh cool that’s what I was thinking of finding, you just made it easier for me lol thanks
Nicholson72
Ca
Ls 5.3
Just got one off amazon it will be here Sunday
rpcraft
Robert
LS 6.0 364 CID
I'd just be sure and check it after a couple of years. Not sure what it is made of but I am sure it will corrode away until it leaks just like most of the cheap stuff they put on trucks now days.
Madhorn
AR-Arkansas
Ken
That’s a great looking part. Had not seen that one. I ran mine to the top of the water pump threw a temp gauge fitting.
Madhorn
AR-Arkansas
Ken
This coming Friday the 77 goes to the AC shop. Before that can happen I need to relocate the coolant over flow bottle due to AC lines now go through the core support on the passenger side. So this weekends projects included moving coolant bottle to the drivers side and refurbish the KC lights.
Camar068
10 yrs Air Force
sweet
Madhorn
AR-Arkansas
Ken
Well, the 77 got dropped off at the AC shop yesterday, felt really weird to leave it there. I almost feel violated letting someone else work on my truck without me there. Oh well, with any luck it will be finished Tuesday and I can pick it up Wednesday.
Nicholson72
Ca
Ls 5.3
Any of you guys have the vss hooked up on the older trannies? I thought about getting the Dakota gauges adapter
Crispy
Carbon County, Pennsyltucky
Suburban V1500
Side note for the steam fitting. Dorman 47147 also works and is made of plastic.
Bhardiman1
