77 Chevy K10 Help w/ removing manual SAE Selectro locking hubs.
MadMike
Des Moines, IA
Michael
Got the other side done. Now i'm doing the driver side.
MadMike
Des Moines, IA
Michael
This is how it comes off.
Remove the screws. Before you pull this off.
Remove big ring from here.
Remove smaller snap ring.
Pull this out.
Remove the ring.
Pull the gear out.
Now you are at the easy part.
Thanks for showing us!
In the first pic, where are the screws that come out?
Thanks Mike. Fantastic How-To with Pics. I think I need to edit the first post or 2 with a link to get to those so it's found in the search engines.
New rotors, hubs, and hub locks look nice. You should be set for a few years on front brakes and hubs.
MadMike
Des Moines, IA
Michael
There are 3 screws on it.
MadMike
Des Moines, IA
Michael
Do you happen to recall if the 6 lug d44 hubs had 2 different bearing sizes also, or was that just on the 8 lug hubs?
Yes there are 2 different bearing sizes for the year i have. The Yukon YP SP706529 is the one i have.
MadMike
Des Moines, IA
Michael
Sure will....:banana-mario: New rotors/hubs, New Brake Pads, New Locking Hubs, New Wheel Bearing, New Wheel Seal, New Spindle, New Spindle Bearing, New axle shaft U‑Joint, I think that's all.:happy107:
3dbello
