76 K10
mrbreeze
Steve
I've got a sm465 to np205, when I check fluid the 205 is overfill and 465 is low. I've replaced seal at adapter but still have fluid transfer? Am I missing something, can coupler allow this?
Mark80K15
Sicamous, BC
Mark
K15
I'm working on the gaskets and seal on my sm465 to np205 also. Here's a kit for them:
Looking at that kit, when you say you've replaced seal at adapter, do you mean the right side gasket or the seal?
If both that seal and right side gasket are working properly, I should think fluid would be contained in the np205 and not enter the adapter. Also, that seal prevents sm465 fluid from entering the np205. The sm465 fluid enters the adapter to lubricate the coupler inside it.
If you say you have fluid transfer, that means there are no leaks in the entire np205-adapter-sm465 assembly, correct? (There is a gasket kit for the sm465 as well, and one of those gaskets goes between adapter and sm465).
mrbreeze
Steve
My 465 drains into the 205 when parked I guess, when I pull fill plugs 205 is overfilled.
kennythetruck
