76 k10 8 inch lift
Strohl97
Pennsylvania
Quinn
Hello everyone, new to the forum!.
Anyways, i just recently bought a chevy k10.
It's somewhat of a project, but nothing too bad.
I am planning to do an 8 inch lift in the next couple months. The truck came with a hideous and unsafe 6 inch body lift and an undisclosed suspension lift in order to fit the 39 inch tires.
Ill finally get to the point here, im unsure of which lift I am going to go with, but am confused about the front axle pinion angle.
If the kit comes with preshimmed springs, or if i have to add shims to get the correct pinion angle, wont my caster be extremely off? Id like to keep away from cutting the axle and turning the steering knuckles if possible. If anyone has an 8 inch lift thay can comment it would be greatly appreciated.
P.s. i am also planning to swap to a 3/4 ton 14 bolt axle so i don't slay shafts with 39 inch tires.
Thanks everybody!
350runner
tx
Ceasar
Welcome!
Sent from my LGLS991 using Tapatalk
Strohl97
Pennsylvania
Quinn
Thanks!
Id also like to add:
I don't plan on doing any hardcore wheeling with my truck. Mostly some fairly deep mud and dirt trails around the farm. So if I can sneak by with a 6 inch suspension and 2 inch body let me know. I dont need extreme articulation haha.
Thanks again everyone.
highdesertrange
kalifornia
mike
k30
well if you want an opinion, here's mine. I don't like bodylifts more than an 1 inch. and I don't like suspension lifts more than 4 inches. I know others will disagree but that's my opinion. so there you go 4+1=5. done deal. let the flogging begin. highdesertranger
Strohl97
Pennsylvania
Quinn
what would be my max tire size without any trimming if I would go that route?
MadOgre
NA
NA
NA
NA
NA
With 5" of lift you probably wil be ok with 35s. 33s for sure! 6" lift clears 35s for sure!
highdesertrange
kalifornia
mike
k30
35's should clear. another thing that's a good idea is to put ORD shackles on the rear of the front springs. they are much more heavier duty than the stock ones and give you about 1/2 to a inch more lift. highdesertranger
sever
