'73 Chevelle SS Wagon (local find)
Camar068
Air Force Supporting Member
10 yrs Air Force
I have a 10 sec video of it idling, but don't have a good way to upload it. Maybe @78C10BigTen can help me out with that again?
Any video's i've put up, I put them on youtube then share/embed that link in my post.
Moderator
yup, seen it a bunch. The cable including the ends look good, but you replace the cable and it fixes the issue. The corrosion will work it's way inside the insulation where you can't see it. Cut that cable you took off and see how far the corrosion made it inside the insulation.
This is what I saw with it installed... looked good:
But upon removal...
Moderator
Camar068
10 yrs Air Force
But upon removal...
cut the connector off and look for corrosion in the wire, if none, you may be able to repurpose on something else. If you do, cut in 3" increments until you don't see corrosion.
Had I seen your pics, I'd taken a wire brush to it to knock off the rust n stuff and tried again. Don't be afraid to pour some Coca Cola on it....dissolves corrosion.....good to keep in mind when on the road and need a last ditch effort (learned that from my Mom lol).
Moderator
Once I determine if it's an original '73 cable or not (I don't think it is), I'll investigate how far the damage goes. I recently bought a hammer-type cable crimper, but I have no idea where I put the damn thing.
Turbo4whl
Downingtown, PA
Wayne
Ok, so... I put in a 12ga fused hot wire to the coil.
...But, am I going to fry my coil in short order? (1)
Should I run the original resistance wire to the coil and the new 12v wire to the distributor separately? (2)
(1) Yes, it will cook, depends on under hood temps, etc, as to how soon.
(2) Yes, and here is why...
When you crank the engine to start, the battery voltage drops. If the coil was designed to run on 12-14.5 volts it would never get that voltage when the engine is started.
The coil is designed to run the lower voltage that happens when you crank the engine. The coil receives the battery voltage (which is lower) when cranking from the "R" terminal on the starter solenoid. After you stop cranking and the engine starts the coil gets the same lower voltage from the resistant wire.
I hope I explained this clearly.
Moderator
Yes, it does get the 12v signal off of the starter during cranking. I never took voltage drop into consideration. I always just assumed it was to provide a hotter spark upon startup.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Was playing with this the other day on my motorcycle. Same ish set up, chevrolet points and 2 2.5 ohm coils, with no resistor the coils were awful hot in short order. Can't see them lasting long with the straight 12 volt, no resistor to them.
Turbo4whl
Downingtown, PA
Wayne
Just some numbers to think about. Years ago, old coils would do 20,000 to 24,000 volts. With higher compression and wider gaped plugs, more voltage was needed. HEI, maybe 28,000 to 32,000 volts. More voltage is harder to contain. HEI distributor caps are a larger diameter to help with this and better wires.
When Ford (bad word) first had electronic ignition the cap was smaller. With in a year or two Ford had larger distributor cap for their electronic ignition.
Back to your coil. Numbers exaggerated. Say you have 9-10 volts when cranking. The coil maybe designed for 7-9 volts gets a boost when cranking. Resister drops the voltage to 8.5 volts when running and the alternator is putting out 13.5 volts or higher.
So the coil designed for a 12 volt system and regular point ignition always has a resister.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
On the subject. Do you know of a 12 volt "oil can" coil that would run with out a resistor? When jacking with above said motor cycle, added a resistor and lost spark, kinda, found later after buying a motor cycle coil (5 ohm) that the brand new battery had went kerplunk.
Moderator
I haven't messed with the coil situation yet. It's currently running without a resistor and has survived around 80 miles so far. I carried a spare coil with me.
Real world driving has shown that nothing has changed with the stumble. My next move is going to be modification of the accelerator pump linkage. Maybe getting the accel pump running in a slightly different spot in It's bore will help.
Moderator
Almost time for a Quadrajet conversion! :confused:
:banana-mario:
I wanted to make the 2 bbl work. It's already there and while the car is obviously not a speed demon, it's no slug either. Plenty good enough to drive around and be enjoyable. Installing a 4bbl would just snowball and get out of hand. That would turn into cam and heads I'm sure.
Rusty Nail
Cowboy of both Time and Space
Russell
350sbc
You say that like it's a bad thing?
LoL
HP jumped considerably to get a 4bbl. (175hp) but i'm teasing you. I support the 2bbl all day. Readin the thread I was thinkin about the accelerator pump adjustment holes on a Quad, no experience with a Dualjet 210.. Sadface. There was one on the C20 when I got her (267) but I threw it away PDQ. :(
That's what you got right?
Unknown power valve adjustment equivalent for a 210....I wonder if google knows.
Hay Siri. :rolleyes:
Moderator
It's a 2GV, just like the one I was always fiddling with on my first car. That one had troubles with a bad stumble too, lol.
crowe-t
