73-87 weld in brace
marks86
Latham, NY
Mark
12v Cummins
so I acquired the weld in steering brace for 73-87 chevy trucks
capture
turns out there are two pieces to it, I have the one circled in red.
1.what does the other odd shape piece do?
2.can I get away with just welding the outside piece?
3.is the other piece an absolute must?
nvrenuf
Mobile, Al.
The second piece goes on the underside of the frame. You need to put it on.
marks86
Latham, NY
Mark
12v Cummins
issue is I got the first piece for free, I found it in a semi truck trailer with the other piece no where to be found, are you saying without the bottom piece it wont work?
nvrenuf
Mobile, Al.
No, it'll work and something is better than nothing. The underside piece ties the frame to the crossmember under the core support. If you're just reinforcing do it but you're fixing a busted frame I'd do both pieces.
That said, you've got a pic to show the general shape, maybe make the second piece.
marks86
Latham, NY
Mark
12v Cummins
thanks!
sever
