73-80 frame body mounts
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
if you've been around these trucks long enough, youll know how much of a pain these things can be to find, and the center of the hole generally rusts out.
asking $25 for the pair of front mounts, and $15 for the drivers side core support/spring mount.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Bump
Moderator Administrator
So these parts are riveted to the frame rails? Did you grind rivets to get them off? They can now be welded back onto another frame, or use grade 8 bolts and bolt them back on?
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Blow the rivets off clean and a handfull of 3/8" bolts will drop right in the holes.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
I had been holding onto them for my 77k20 in case I needed them.i have a complete 73-80 frame stub in the shed, plus the hours mounts I uncovered when ki rolled the cab off of my 80 last night.
Camo
mobile
1500 extended cab 4x4
4.8 V8
I usually drill the rivet heads off and then bolt them to the frame with grade 8 bolts. Works great.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Bump
elstm3
montana
lynn
V30 crew cab dually
6.2 twin turbo diesel
Hey GreaseDog do you still have the core support/body mount?
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Yes I do. I'll have to get back with you on shipping. Do you need the other side as well? These were just my extras, think I have another complete set too.
elstm3
montana
lynn
V30 crew cab dually
Yea i would be interested in a whole set. The two front core support and two frame hangers on the rear of the front leaf springs.
bvandrey
