Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
Sounds familiar
So they are factory huh?I've got a set of those in dark red. They came with my '84 C10, I think they are from the late 80's?
Mines just like that tooWill a gap in the lock ring cause a leak in the corners (both lower) between the gasket and windshield?
No leaks between the glass n gasket?Mines just like that too
Yeah it doesn’t make much sense to me but I was hoping it was flooding into the corners and up through the lowest pointIt shouldn't cause any leaks from the gap in the lock strip itself as the gasket is a single piece, It could potentially leak between the window channel and gasket or windshield and gasket but I find it unlikely due to the small area.
No. I get the same leak you get, both corners. More like a seap though...No leaks between the glass n gasket?
