Bolt Sizes
Doppleganger
OH-MI: Just like it sounds
1985 std cab. Anyone know where one could find the size (size and thread pitch) for cabin bolts? I need them for the dash to A-pillars, and then the bench and seat belts. Some are SAE - some are metric. I can try to fit old bolts but want to know the correct size so I can run a tap through it and clean them up. No idea where all mine went.
4-bench seat bolts
3-seat belts to floor
2-seat belts to shoulder
3-dash to a-pillar
4-body mount boss on cab (1/2-13?)
THX
Doppleganger
I think I've got most figured out - only oddballs now are the seat belt bolts. I actually have all my originals but they dont fit correctly. PO cobbled about everything else so who knows. I do know that the shoulder points are different (metric) and iirc the lap bolts are SAE (in all cars). Crazy.
legopnuematic
Licensed Junk Dealer
MO
Spencer
My 79 the shoulder belt mount on the B pillar is 1/2-13 and the lower mount points on the floor are M12x1.75.
Bench seat should be 3/8-16.
Dash to a pillar? I assume you mean the ones behind the dash that taking them out gets you nothing (since the dash is spot welded in)? 5/16-18.
Cab mounts 1/2-13.
This is all based on my 79, Id expect for the most part for things to be the same for an 85.
Doppleganger
My 79 the shoulder belt mount on the B pillar is 1/2-13 and the lower mount points on the floor are M12x1.75. THANKS!
Dash to a pillar? I assume you mean the ones behind the dash that taking them out gets you nothing (since the dash is spot welded in)? 5/16-18. YES
Thanks Lego! I'm going to run a tap through the bosses to clean and straighten the threads - the bolt threads (seat belts) are a mess so needed to know for a fact what they are supposed to be.
You da man - thanks again :hat:
The Right side of Washington
You got er painted?
Fat 454
Australia
C20 Suburban
The seat belt anchors are usually different to everything else. Often metric, shouldered, hardened and a fine pitch thread. I think this was partially due to the "duty" specifications of the belt / bolt anchor, and that safety reg. requirements changed more often than model design ( ie. all the other assemblies could be carried over year on year ).
Make sure you have the correct belt bolts / thread / shoulder etc. You will then need a matching tap set to clean out the receiving nut in the factory re-inforced panel. If the threads are loose and have been "monkeyed about" with, it would be safest to replace the re-inforcing panel altogether. Junkyard searches are probably the best place to find the "correct" parts, however once you know what was originally fitted aftermarket seatbelt suppliers can provide new hardware.
You and yours are depending on these re-inforcing point to perform, so don't make do with "good enough! "..
NikiFm
