700r4 to t5 swap?
chevy355s10
Lake City,SC
I know it wont hold much. but im looking into a t5 swap into my '84 c10. just want a stick shift and the fun that comes with it. I just don't know which one to use. I know its gonna be a world class. but out of what vehicle? im kinda at a loss here. not used to doin THIS kind of swap.
marks86
Latham, NY
Mark
12v Cummins
IMO a nv3500 out of a early 90s chevy would be a lot easier swap
chevy355s10
Lake City,SC
I found a 4 speed out of a 76 c10....could yall tell me about It before I buy it?
If the T5 came from a Camaro or Firebird, it should basically bolt in. But it will not be very strong.
The truck 4 speed... 1st gear is a granny gear I assume? It's very strong but if you want sporty type shifting, you won't be happy with it. It has dump truck-ish shift characteristics.
chevy355s10
Lake City,SC
ok...im looking at the v6 post 1993 s10 tranny with the astro van bell housing.it has the Camaro gear ratio and will clear my bench seat. I am gonna try to use a hyd setup. what would I need to do to make this work?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
a t5 is not strong enough for a truck
sorry to say but you are wasting your time t5 transmissions are barely strong enough for a car even the world class t5 will not hold up to a truck
Can you tell me more? What's different about the Astro bellhousing? That has to be a rare piece.
chevy355s10
Lake City,SC
with the astro bell housing. it has a sbc bolt pattern,the hydraulic setup and you dond need to cut anything with you input shaft(no shims needed either.) or the throw out bearing retainer. makes it a bolt and go kinda deal with out any worry as long as you buy the astro clutch kit to go with it.
chevy355s10
Lake City,SC
this is gonna go into a truck that weighs about 35-3700lbs. if they came in an astro van with a curb weight around 4300lbs, I should be safe,right? I mean...the obvious difference would be a v8 vs a v6. but I wont be pounding on it. it wont be a drag truck. no 3k rpm dumps or speed shifting. the only real reason I feel comfortable with it is because me uncle is still using a stock t5 in his mustang that runs 7.30's with a 125 shot. been using it for 10 years. maybe a stroke of luck,but it works.
sallyjeank10
