700R4 install questions
MadOgre
NA
NA
NA
NA
NA
What carb do you have? Do you have the cross member for the 700r4 adapter? What gears do you have? What year transmission do you have?
Do you have a matching transfer case?
76K20
Pennsylvania
Alan
K20 Scottsdale
Qjet, No I was going to adapt the crossmember that's in it. 4.10 gears and tranny is an 87 out of a suburban with matching tcase.
MadOgre
NA
NA
NA
NA
NA
You need the cross member from the Suburban.
MadOgre
NA
NA
NA
NA
NA
Well Im guessing that you have a TH400 in it currently ? Anyways the 700R4/208 or 241 is not gonna bolt to your 76 cross member.
MadOgre
NA
NA
NA
NA
NA
The 700R4 uses a different height and width of adapter than what you have
76K20
Pennsylvania
Alan
K20 Scottsdale
Actually I have a TH350. That's what I meant when I said adapting the cross member I was planning on making a plate to fit the 700R4 to the existing trans mount.
MikeB
North Texas
No reason why that won't work.
MadOgre
NA
NA
NA
NA
NA
Oh ok. IT would be easier if you could just go grab the cross member from the burb. But if you can mill something up then that could work too
Just make sure you get the lock up to work before using 4th (OD) gear.
76K20
Pennsylvania
Alan
K20 Scottsdale
Just make sure you get the lock up to work before using 4th (OD) gear.[/QUOTE]
That's what the kit from Bowtie OD is supposed to do, I hope.
76K20
Pennsylvania
Alan
K20 Scottsdale
The burbs probably been reincarnated into something in china by now. Although I can still get the computer if I need to but I have no flippin idea how to hook that up.
MadOgre
NA
NA
NA
NA
NA
No need for the computer unless you want to run the TBI from it. The 1987 700R4 is completely mechanically operated aside from the electric lock up. which is still not computer related. The TV cable does everything the later electronic controlled transmissions use the ECM for.
76K20
Pennsylvania
Alan
K20 Scottsdale
Thanks for the help MadOgre. I guess I'll know if alls going to work by Saturday evening.
MadOgre
NA
NA
NA
NA
NA
Ya hope it goes well! Make sure you post some pics and keep us up to date
aaron06
