6 inch lift or 4 inch lift
chevydude
arizona
hunt
k20
Hello I have these front leaf springs not sure if there 4 inch lift or 6 inch lift. It is on a 80 blazer. There is a defient arch I just can not tell how much lift there is. How can i tell they are defiantly aftermarket. they have red bushings and they are rancho. But i can not tell what kind Does anyone have a pic of a 6 inch front leaf spring so I can compare. Or a description of how much arch
Thanks
8T6K5
AZ
L98 350 TPI
If bushings are red, good chance they are Rancho...their PN's are usually painted on top just about where the spring plate would go.
Considering paint might wear off it may even be stamped.... something like RS86206
Chaz
USA
Chaz
V1500 Suburban
350 tbi/th400/np241c
My front springs have the red bushings,,,,,they squeak like hell all the time,,,im gonna go check and see if theres any rs number painted or stamped on em,,,,i was told there 6 inch lift,,,I dont think theres an easy way to tell how much lift springs are unless thy got a part number on em,,,,guys at 4 wheel parts couldnt tell me how much lift I had on the trk
8T6K5
AZ
L98 350 TPI
Doesn't surprise me.
Sent from my iPad using Tapatalk
elstm3
montana
lynn
V30 crew cab dually
6.2 twin turbo diesel
since we are on the subject of figuring out lift springs how about this one? I havent thown a tape on it to check the differece yet i just took a quick pick.
Hard to tell when they are not installed. Look like 6 inch though.
1986K30
Colorado
Sam
7.4L
They look close to my 6" springs on my floor. I'll try and get a pic for you.
1986K30
Colorado
Sam
7.4L
Here this may help you. The more I look at yours, they look like 5 leafs when mine are 6. I'm thinking maybe you have the 4" pack.
82chevy350
Van Buren, AR
Joey
C10, K10, K5
Is mine a 4 or 6 inch those are 32s...
I also found out i have a raised steering arm and a offset skyjacker draglink along with dual stabilizer system off the parts truck i bought
1986K30
Colorado
Sam
7.4L
Looks like 4" to me.
dirtroadoutlaw
Florence, MS
k5
You should grease them. That's actually proper maintenance. DIY4X sells bolts with grease fittings in them and drilled sleeves to make this possible without disassembling them every time they need grease.
8T6K5
AZ
L98 350 TPI
Replace-Add new teflon tabs at the ends of the leaves.....
