6.0 swap 76 chevy
TheFishBox
OR
nick
v30
6.0 ls
I am looking at getting a motor from tilden motorsports. So what I have is a 76 gmc 2wd that I am planning on putting on top of a 4x4 1990 chevy frame to make the truck 4 wheel drive. So I have a few questions for you guys in the quote I received from them they quoted me for a fuel tank with ls rated fuel pump at 1500 bucks is this a required thing or can I use the tanks I already have with some modification? An ls swap crossmember for 300.00 seems a bit steep seems I could fab one up for less, pro series oil pan for 500.00 and a fuel system plumbing kit for 300.00.
So what do you guys think about these items? This would be my first swap I am trying to gather the pieces I need and get an idea of what it is going to cost me.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
If you are using the 1990 frame, all you need to do is drop in a high pressure pump using the 1990 gas tank. ACDelco EP381 is a good option. Are you using a GMT400 frame? If so, not really sure on the fitment for oil pan and etc.
Camar068
Kentucky
10 yrs Air Force
lol good lord at those prices! What are you paying for the engine?
yevgenievich
Place
Name
Year
Model
Size
The prices make it sound like a pro touring 1500hp build. Maybe typo on fuel tank price? For a simple 6.0 swap, an upgraded fuel pump on gmt400 chassis or new 87 tank with upgraded fuel pump on original chassis. Engine mounts are usually about $90-$150. Often stock transmission crossmember works just moved to a different location on the frame. All new fi fuel lines could cost up to $300.
TheFishBox
OR
nick
v30
6.0 ls
no typos there. 3,500.00 was the quote for the motor. I thought the prices seemed a bit high. does anyone know of a good place to get a motor for this swap I have been watching craigslist but haven't had much luck. I am going with the 6.0 just to have something a little different rather than going 5.3.
No it's not a 1500 hp build.
yevgenievich
Place
Name
Year
Model
Size
Could you confirm which chassis you going with? Look for lq4 if on a budget, lq9's will tend to run around 2k price range. There is one on craigslist local to me, rebuilt 6.0 short block with stock wiring and accessories for $2k.
TheFishBox
OR
nick
v30
6.0 ls
yeah it's a gmt400 frame. That I am swapping the body onto to achieve 4x4.
c10racetruck
Massachusetts
Craig
c10 Scottsdale
5.3L
check out bow auto on ebay, they're out of New Hampshire but they ship all over the lower 48. i got my 5.3 lm7 from them, its a total delete kit, engine, engine harness, air box, gas petal if its dbw. reasonable prices, very helpful to talk to.
TheFishBox
OR
nick
v30
6.0 ls
I will take a look thanks for the heads up.
yevgenievich
Place
Name
Year
Model
Size
I believe EP381 is the fuel pump you would need. Came on vortec motors in later years. Also 255 is a common upgrade. Both should work in existing tank, maybe with a bit of modification.
Camar068
Kentucky
10 yrs Air Force
$59 before our 5% off.
