5 lug to 6 lug 1983 GMC
Moderator
yep I figured, just rattling chains, a little.......lol......and yeah I don't understand going to 6 from 5???????
From 6 to 5? On a 2-wheeler, I'd do it for looks. The 5 lugs looks better than 6 (imho) when you've got the typical 5-slot or 5-spoke wheel.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
?.............I would rather have a 5 lug than a 6 lug,...... isn't that what I said? You're confusing me ......My post says TO 6 FROM 5 @bucket
Joined Monday 9:28pm last seen Monday 9:53 PM I think it's safe to say O.P. is gone
Moderator
I thought you meant the other way and you were changing the subject.
So correction... you're confusing me!! But to be fair, that's getting to be easier these days, lol.
blusneau
Houston
C1500
Sorry guys I've had this truck since 1984 hand me down from my Dad I was looking to change the rims and most of the ones I want are 6 lug only so hence the change. I already found the rear axles I need just been having trouble withe the front end.
#4 and #13 both have usable solutions.
The Right side of Washington
Eh no worries. We can be a tough crowd. Best of luck with the swap.
Whisper6691
Bobbie
It's a bit pricy but it can be done with a front end swap all at once and make it rack and pinion at the same time. But it will give the truck a much better handling and steering capability. https://www.summitracing.com/parts/hli-9075399
Had considered this on my 85 as well. But like the rest decided to keep it 5 lug more wheel options.
JBswth
Vallejo, California
James
C25
292 cubic inches
Get off of my lawn!!!
As far as I know, the rotors and rear axle shafts for a K10, which used 6 lugs, will interchange with those of a C10, PROVIDING you get axle shafts for the same type of rear end - 14 bolt to 14 bolt, 12 bolt to 12 bolt, etc. Check and make sure that is still true on 80s trucks. If so, that is the easiest and cheapest way to change over. No fabrication, no aftermarket parts, no problems.
J. B.
Fat 454
Australia
C20 Suburban
you'll be handing out the hot wrenches and the left handed screwdrivers any minute ...
Nborden88
