5.3 LS w/4L80 Mystery Noise
Rustybucket73
SF Bay Area
'73
C10 Stepside
5.3 LS
Just finished up budget LS swap on a '73 C10.
Bone stock 5.3 from a suburban
4l80e with a HD2 kit, stock converter
Has a weird noise when ever I rev up to around 2500rpm while parked. Noise also comes back around the same rpm while driving.
Converter is seated all the way in the pump.
Exhaust has v-bands and has some leaks, but I don't think a exhaust leak sounds like that?
Any idea what it could be?
Noise is in the video about 30 seconds in.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Sounds like your flex plate is living up to its name.
Rustybucket73
SF Bay Area
'73
C10 Stepside
5.3 LS
I guess I can take that as everything is fine?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
No it sound like it rubbing somewhere. Look in around the flex plate and converter for scrape marks could be a crack in the flexplate too. And welcome to GMSB
Rustybucket73
SF Bay Area
'73
C10 Stepside
5.3 LS
Ok, thanks. I'll check it out
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
2x flex plate look close between the holes in the flex plate
74 Shortbed
Flex plate is broke or loose...
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Sounds like the flexplate is rubbing or something.
Did you change to the flat 6.0 flexplate?
Jrgunn5150
Ionia Mi
J.R.
6.slow
Yeah, it has the 6.0 flexplate and spacer
And longer bolts?
Is it hitting the oil pan? Are there any witness marks anywhere?
I've found my phone to be a really handy tool in shoving weird places and taking photos that I can then review.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Rent a bore scope and shove it up around the flex plate.
Jrgunn5150
Ionia Mi
J.R.
6.slow
Or just recklessly stick your phone places like I do lol.
Rustybucket73
SF Bay Area
'73
C10 Stepside
5.3 LS
Want to update the thread.
Took the trans off the motor and inspected the flex plate.
No cracks around the crank bolt holes or anywhere else on the flex plate.
Didn't see any rub marks on the inside of the bell housing or on the engine behind the flex plate.
Re-torqued all the crank/flex plate bolts to spec and put everything back together.
Still makes the same noise.
Now I'm thinking its the pump?
mick84
