4l80e conversion in 1985 suburban. What parts do I need?
NickTransmissions
Las Vegas
Nick
Installed the transmission and drove the first time today. Either this shift tune is bad, or something else is off. This thing feels like a dog now, shift points are too low and worst of all, this thing shudders like a mother when the converter locks up in 4th gear.
Perform a driving line pressure test. Short shifts and TC shudder is likely low LP across the board, which is probably C3-driven. If LP is low, contact the company that man'ed or sold the controller for tech support, if you havent already done so.
txaggie
austin texas
kris
suburban C20
Thanks Nick. It’s a Holley sniper trans controller and all the line pressure looks to be pretty similar.
What is “C3 driven?”
NickTransmissions
Las Vegas
Nick
C3= communication, command and control.
What exactly are your line pressures for all range positions at idle and at stall?
txaggie
austin texas
kris
suburban C20
Found the issue. Shudder is most likely a burnt plug wire and dead cylinder:
txaggie
austin texas
kris
suburban C20
Nick,
After we got the plug wire fixed, it drives pretty good. However the second gear shift is really hard and others are not. Also, after normal highway driving, this thing heats up to 210 ish with nothing being pulled and I have an extra Derale cooler in junction with our radiator cooler. Does this seem a bit high? The turbo 400 without pulling wouldn’t get above 180-190.
Today is hot though, 98 degrees.
txaggie
austin texas
kris
suburban C20
Nick,
Just went and drove the crap out of it. Trans temp warmed up to 205 and then cooled back to 198.
I’ll take this to my buddy this next week and get it tuned (engine and trans).
Markgockley
