4hi popping out
royc
long island ny
roy
K 10
does anyone know why 4 hi pops out constantley have to hold in
place? what do i need to fix it thanks in advance roy
royc
long island ny
roy
K 10
forgot manuel hubs 208 just use it for when it snows thanks again
Could be worn body mounts or worn engine/trans mounts.
Shifter linkage needs adjusted.
I agree with you, but wouldn't the fact that it pops out while driving often mean the t-case or body is moving around?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Not always. That blue 83 I had last year kicked out of 4-Hi all the time. The guy I sold it to said they adjusted the t-case shifter linkage and fixed it.
royc
long island ny
roy
K 10
who needs a machanic with U guys around thanks again roy
1. Position transfer case shift lever in 4 Hi detent.
2. Push lower shifter lever forward to 4 Hi stop, then install rod swivel into shift lever hole.
3. Install 0.200 inch gage behind swivel as shown.
4. With shifter against 4 Hi stop, tighten rod nut (A) until it contacts gage.
5. Remove gage, then push swivel rearward against nut (A) and tighten nut (B).
Dons79C10
