400 vs 475 ??
redgrizz
NW PA
Just completed a 4 year build on our 85. It has a 454 bored out .030 and all the extras. First couple trips to local shows, i noticed the th400 seams to slide through 2nd. 1st grabs hard and so does 3rd. Any ideas? I'm not a trans guy. But if its rebuild time, i do have a 475 as an option. Thoughts on which why to go? The truck rolls on 39's with stock 4:10 gears. Could this be a simple modulator valve failing? Thanks in advance.
marks86
Latham, NY
Mark
12v Cummins
replace the modulator valve on the side of the trans it costs like 12 bucks you can adjust it by a tiny screw inside it also
guillermoariast
