400 trans acts like its in neutral
ToddM
Elk River
k20
383 Stroker
I have a 383 hooked up to a 400 and it seems like the pump went out on the trans after rebuild I only got 75 miles out of it.
The builder says that he thinks there is t enough clearance for the torque conv?... Behind the flex plate there is an external balancer. That's only and 1/8 inch thick. Anyone ever heard of not enough room for a torque converter. He say it burned out the pump. I smell BS.
LET ME KNOW.
THANKS.
74 Shortbed
When you put the tranny in you would have had to slide the converter forward a 1/4"-3/8" to the flexplate, if it was right up against the flexplate the converter wasn't engaged in the pump properly and it killed it.
Rusty Nail
Rusty
350sbc
Yep.
Point your finger at the installer.
fastwagonfab
