4-light headlamp connector ID
ozone160
Colorado
Geno
Hello, can anybody out there identify this broken part? It fits into a 1991 Suburban and holds the headlamp harness to the bulb by clipping into the headlamp housing. I recently installed the battery/relay swap to power the four headlights and all four clips broke. The new harnesses didn’t include these and fit a little too loose. I can’t seem to find the part number or even what GM calls it. Searching on the net has been fruitless. I’d like to see how much they cost to decide if I buy, or if I should make my own.
@82sbshortbed Isn't this something you dealt with not that long ago?
ozone160
Colorado
Geno
?? Not me. Started project last weekend. Still can't find info on buying new ones.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I do have the suburban grille on mine with the 4 headlights but it's a bit different. I got all the new lights and hardware from Lmc for about 100 bucks. I'll look in my build thread for pictures.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Maybe this helps. I couldn't find the pictures of mine.
gmbellew
Kansas city
glen
suburban 1500
I have those on my 90. as you said, they exist to keep the headlight connector connection solid. I don't see a part call out for them in any of the manuals, but I didn't complete an exhaustive search. maybe you could just fix it with a bit of pipe strap, a drill to make holes in the plastic, and some small bolts and nuts?
ozone160
Colorado
Geno
Connector harness update
Found this on Australian Ebay, $45 plus 12.50 shipping https://www.ebay.com.au/p/1248260462.
I can’t justify spending over $100 USD to get four plastic clips. However, the part number is 12046532 for future reference.
With gmbellew’s suggestion of a pipe strap I started gathering stuff to make my own harness clip. When I pushed a zip tie through the holes I decided that’s all it needed. Nice and snug, not going anywhere. Four zip ties for less than one dollar :)
Here’s a close-up pic of the driver’s side.
Threw a couple extra zip’s in my emergency road kit. Clean it up with a quick snip of the dikes and I’m calling this headlight relay project complete.
di11ard
